Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
My iPhone 6 wont turn on
today i woke up to see that my iPhone 6 didn’t come on so i tried to plug it in but it didn’t work,then i tried to hold the home and power button together still didn’t work when i plugged in my charger to the phone it doesn’t come with the battery low page that it usually does when your phones battery has been low . its just seems like its dead no i didn’t drop my phone or drop it in water somehow its just dead. i even got a new charger and pluggedf it to the wall and computer still nothing…
Это хороший вопрос?
Оценка 0
Добавить комментарий
5 Ответов
Can you see anything on the screen
if not from what you are saying I be checking the condition of battery and the screen to see if one of them are at fault ??
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
the screen is in good condition
из
How do you know the screen is in good condition??
из
Hello, if you’re sure that the charger works fine then the problem might be your battery or a hardware problem preventing the phone to boot correctly, remove the battery for 5 mins and re-plug it again.
Оценка 0
2 Комментариев:
but how do it open the phone? or will i need tools ?
из
yes you do need tools So better if you bring it to a repair phone shop to sort the issue
из
You can hook it up to iTunes on your computer and see if it is recognized at all,maybe in dfu recovery mode.
It what charger do you use? Is it a generic charging cable or an apple original?
It can also be a short on the board. The first step is hooking it up to iTunes. See if it is recognized at all. If it is recognized normally,it’s probably a display issue.
If it it is not recognized,you need to take it to a repair shop that can diagnose it. They can check if it’s a bad screen,battery,or even a board issue. If it is a board issue,it would require a microsolderer to repair it,which usually means you have to mail it in for repair,unless you happen to have a shop nearby that solders. Ipadrehab is a good repair shop in New York. They are professional micro solderers. So keep them in mind if you need to send it out.
Let me know how it goes if you want…
Оценка 0
1 Комментарий:
Thank you so much will do!!!
из
If your iPhone 6 doesn’t suffer from physical damage or water damage, try the following methods:
  1. Force restart the iPhone 6;
  2. Restore iPhone with iTunes after making a backup;
  3. Put the iPhone into recovery mode or DFU mode. If no backup, this method will cause data loss;
  4. Try Joyoshare UltFix iOS System Recovery when common ways cut no ice. Such a tool is a professional iOS system repair tool for various iOS problems solving without any loss.
Оценка 0
Try a different charger, cord or both. they do stop working eventually.
if those are ok, investigate the charger port….make sure its clean, and the
lightening plug is snug. also look in the port with a flashlight and magnifying
glass and look for any missing or bent gold contact points.
good luck
Оценка 0
Добавьте свой ответ
Chloe Norfor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 100
