Kohler makes the gas powered engines for many different riding mowers & garden tractors both for home owners and professionals.
15вопросов Показать все
No spark, lots of new parts
Here is my dilemma. I have a kohler cv18 command pro that has no spark. I have replaced the master wire harness (because is was butchered when I bought it), engine relay, coils, plugs, stator & the battery. I can’t figure it out. The only thing I haven’t tried is replacing the starter.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @ryan042204 ,
Here’s a link to the service manual for your engine, found on this webpage. (Scroll down the page to find the Kohler Command Pro Vertical Twin Service Manual CV17-CV18-CV20-CV22-CV23-CV25 CV624-CV640-CV670-CV675-CV680 CV724-CV730- CV740-CV750 entry)
If you click on the service manual link above it will download automatically to your computer.
On p.41 of the manual it details the Electronic Ignition Systems tests which may help you to find your problem
Был ли этот ответ полезен?
Оценка 2
Check the wire that runs between the could packs . There's a tiny resistor in the wire . Good luck
Оценка 0
Добавьте свой ответ
Sabian Abel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 31
За всё время: 592
