Игровая приставка от Sony Computer Entertainment, анонсированная 20 февраля 2013 года и выпущенная 15 ноября 2013.
1697вопросов Показать все
HDMI PORT can damage if I plug and unplugging it many times?
hello i have question !! I want to know ifi unplugging / and plug the cable hdmi (or even the power supply) many times , can damage the ports? even if i unplug and plug very carefully ? .
I'm scared for my ps4 :’(
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Выбранное решение
The port can wear out over time. Depends on quality of the HDMI cable for example if one was very hard to plug in it can damage the port quickly.
Also take note that unplugging and plugging it while it is switched on a lot in short succession will kill the HDMI chip over time in my cases it took a few minutes.
I have confirmed this when testing.
If you want to be safe which is recommended only unplug the HDMI cable after the power cable is disconnected and/or when the PS4 is turned off fully.
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
Unplugging/plugging devices frequently (several times a day, for instance) shouldn’t damage the device anytime soon. Physical damage to electronic devices are usually due to accidents or misuse.
Оценка 3
I plan on installing a 6 inch extension on my hdmi device, and leave it in place, that way if you damage the cord, you just replace it. The hdmi input/output will remain in good shape.
Оценка 0
Yes and it is important especially with boys who love video games to get the hdmi box with multiple ports..my son age 9 would switch from his video game to live tv so much and he would unplug the cord from the tv hdmi port alot and eventually it could fray the hdmi port …the wires were visible in my case…if they yank the cord or be careless while putting it back in or taking it out the port ,it will get damaged…so if the tv is for your use…normal use then a hdmi box is not needed…but if you are connecting to multiple sources ..then yes get you a box…
Оценка 0
Добавьте свой ответ
Silver Bullets будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 20
За последние 30 дней: 125
За всё время: 19,619
