The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
24вопросов Показать все
I wiped my hard drive by mistake
would that get me access to the tablet again ? currently i cant access it as i wiped it and cant recover it. Or will replacing the mother board do nothing and put me in the same boat im currently in now -with having to reinstall the OS ?
Это хороший вопрос?
Оценка 0
4 Комментариев:
is the recovery partition still on the device?
из
no sadly i wiped it :(
из
Yes by replacing it you be running again
из
My next question is replace the motherboard or trying to flash the current one that has been wiped ? I mean there must be a way to flash it..no? They do it at the plant I literally have a clean slate hd/motherboard there must be a way to flash it ...if I can't is the original Motjerboard 2015 shield the same is the shield k1 version circa 2017
из
Добавить комментарий
1 ответ
Start with this in fastboot mode:
https://twrp.me/nvidia/nvidiahshieldtabl...
Flash the TWRP - then you can search XDA to get a ROM to flash https://forum.xda-developers.com/shield-...
https://wiki.lineageos.org/devices/shiel...
Recovery: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed. Tap Volume Down until recovery is selected. Press Power to select.
Download: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Andrew Brown будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 190
