An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
Вопросов 20 Показать все
SSD upgrade causes iMac 2015 to freeze after minutes of use
I upgrade my iMac to an SSD and once it boots up after minutes during use it will freeze completely and will not be responsive to anything. I have enabled TRIM settings but find that it is still doing the same thing. What comes next?
Это хороший вопрос?
Оценка 0
1 Комментарий
Can you tell us more details on which model iMac you have as well as the exact SSD you used (make, model and interface SATA or PCI).
из
Добавить комментарий
Ответов (1)
Выбранное решение
Sorry actually I figured it out apparently I just needed to do a complete wipe of all data and reinstall the OS in recovery mode and now everything is good !
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jerrell Jones будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 125
