How to change ignition
Это хороший вопрос?
Here are the instructions for replacing the switch:
Disconnect negative battery cable. Remove steering column upper and lower covers. Remove screw(s) retaining ignition switch to steering column. Disconnect ignition switch harness connector. Remove ignition switch. To install, reverse removal procedure.
Был ли этот ответ полезен?
hope this helps
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 749
James Clark ignition what? You need to tell us what the issues are and what you are trying to accomplish. Try to use more than 4 words ....;->
из oldturkey03
@James Clark Do you want to change the ignition switch assembly, if yes, do you also have a security system (anti-theft)? Typically you will need a hammer and very sharp chisel as part of the process but lets see exactly what it is that you need to do first please.
из Duane Donaldson
With lock cylinder, or without?
or,
Ignition module?
Ignition lockout/immobilizer?
Ignition relay?
More information required.
What are the symptoms, or how was the ignition diagnosed as the issue?
Help ‘us’ help you!
из Mark A. Hemingway
My bad, just saw someone covered those details, thank Turkey and Duane, they're right on point.
Regards.
