Выпущено 21 сентября 2018 г. Модели A1921, A2101, A2102, A2104. Доступен как GSM, CDMA / eSIM или nano-SIM / 64, 256 или 512 ГБ / серебристый, золотой или космический серый. (Произносится как «iPhone 10 S Max.»)
375вопросов Показать все
iPhone XS Max restarts every 4 minutes after screen replacement
I have an iPhone XS Max that appeared fine after a screen replacement. The screen is aftermarket, and the phone now restarts every 4 minutes. Everything seems to work fine in those 4 minutes, battery charged, cameras work, touch works, receives texts, makes calls. Is it just a bad screen? Already tried updating all of the apps and even restored the phone. I have the phone coming back in and will put the original back on to see if that fixes it. Any ideas?
Это хороший вопрос?
Оценка 4
7 Комментариев
update: phone came back in and original screen did not fix the problem. Have tried to restore again, and use TenorShare to fix any issues software wise. Still no luck.
из
Any update on this issue?
из
Still no updates or answers from anyone
из
Welcome to the modern times of aftermarket screen replacements.
из
Hey Matt,
I used to work for Apple and am assuming you did the screen replacement at a place that wasn't through Apple. You mentioned you already got the original screen back on which didn't help to fix the restarting issue. Is that phone still under the original 1 year warranty through apple? I assume that you didn't get Apple care otherwise you would have done the screen replacement through them?
из
Показать 2 больше комментариев
Добавить комментарий
2 Ответов
Наиболее полезный ответ
The charging flex cable might have been damaged during screen replacement. Or you can also check the USB IC as mentioned in the repair guide here.
A rare case of iPhone X Keeps Restarting - Motherboard Repair
Был ли этот ответ полезен?
Оценка 2
change the frames 100% worked!
Оценка 0
1 Комментарий:
What do you mean change the frames
из
Добавьте свой ответ
matt mocciola будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 25
За всё время: 4,098
