A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Black screen on MacBook
Hello, so today I went to turn on my MacBook, but I was met with a black screen . Yes it is charged, yes I checked to see if the brightness was down, and yes, I tried all of the VRAM reset solution things that are suggested. None of them worked. The MacBook itself seems to turn on, as in all of the keys are lit up, and the caps lock lights works, but it seems that the problem is with the display. I have also noticed that when I shake my MacBook, I can hear and feel something moving around. Is this the issue? Did a cable get unplugged or broken?
Это хороший вопрос?
Счет 1
1 Комментарий
most probably your unit was subjected to fall, thus you hear there is something loose inside. the bad news are that all the connectors are fixed with the retainers by screws, so what you hear most probably are some of the screw's mounts are broke off. take a look inside. avoid further shaking since you never know where those loose parts will end up in there. avoid powering the unit on if you can. post the pics with what you'll find.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@ckelly27 … could be a backlight issue. try to shine a flashlight at the screen or behind the back on the apple logo to see if you can see an image. if so, the backlight circuit needs to be repaired. if not, further diagnostics are required.
post back with findings for any additional assistance.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Cameron kelly буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 14
За всё время: 224
