The projector has green and red lights flashing on top with power on
Can I use usb cable to run the projector. All out of hdmi ports on back of Xbox x
Это хороший вопрос?
Это хороший вопрос?
Hi,
According to the DG 737 LED user manual, the only signal sources accepted by the projector are HDMI, Component video (Red/blue/green +red/white audio), Composite video (yellow + red/white audio) and vga.
Not quite sure what you mean by connecting via USB as the “Video output for the Xbox One X console is HDMI only”. Quote from Xbox One X user guide (if this is the model Xbox you’re referring to)
Perhaps you could investigate the possibility of using a HDMI splitter - info only to connect an already in use HDMI output on the Xbox, to the projector
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 12
За всё время: 924
