Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Вопросов 20 Показать все
Dodge CARAVAN 2003 Why does my van stall?
Hi..thought it was the fuel filter so replaced that but van still stalls after driving for a couple of miles. Bought fuel injector spray…no luck. Neighbor says it is not the fuel pump. Car starts again after it cools. Kristina
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (3)
Выбранное решение
Clean your throttlebody, sounds like as long as the engine is cold, the computer controls a little extra air into the engine and it runs good, as soon as the engine warms up, the idle controller no longer is bypassing air and the engine stalls. Will it run better with the AC on? If you keep your foot a little on the gas pedal, can you keep it running a little bit off from idle?
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Yes Duane.that is exactly what happens THANKS
из
If the cleaning doesn’t do the trick, maybe replace the pcv valve, about 5 bucks at the auto parts store.
Оценка 1
Thanks Joe! If throttlebody cleaning doesn't help will replace pcv
Оценка 0
Добавьте свой ответ
Kristina Daniels будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 172
