{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
199вопросов Показать все
Why is there a blue vertical column on my display.
This morning when I turned on my Mac I noticed a blue verticle column in the 2/4 of my display (the far left being the 1/4). I saw that depending on the orientation of my screen the column would either go away are the whole screen would go black.
Это хороший вопрос?
Оценка 0
2 Комментариев
Can you post a vid or pics showing us what you see Adding images to an existing question
из
@danj Yea for sure!
из
Добавить комментарий
2 Ответов
Выбранное решение
Not good ;-{
The ribbon cable between the T-CON board to your display assembly has a bad line.
This is a similar issue to the The Design Flaw Behind MacBook Pro’s “Stage Light” Effect problem Apple had. Here the ribbon cable likely got damaged from a bang hitting the black clutch cover which then compressed against the cable damaging it.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Would it be best to send it to Apple to repair, or should I fix it at home?
из
If you still have AppleCare I would let Apple deal with it. Don't wait as you don't want it to expire on you.
If you have AppleCare+ service contract they might charge you (at a reduced price) for the needed part (new display assembly).
из
Can someone help me? My laptop fell and it showed this:
Оценка 0
1 Комментарий:
[image|22t32837] I dont know how this happend
из
Добавьте свой ответ
Sami Tayfour будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 35
За всё время: 2,860
