Device repair and information for the Dell Alienware 15 R3, a gaming laptop in the Alienware series.
Screen flickering right part of the screen
Hello , I have a problem with my laptop i don’t know what cause this problem and i just wanna know if this a software problem or hardware problem maybe cable or the entire screen is now broken
here is the video showing the screen problem Video 1 Video 2
Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Try connecting an external monitor to the laptop and check if its display is OK.
If it is then you may have a hardware problem.
It could be a loose video cable connection to the systemboard, a faulty video cable (trying pressing on the left hinge area to see if you can make the problem come and go) or a faulty LCD panel.
Here’s a link to the service manual for the laptop.
Scroll to p.85 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
This should give you access to view the cable connection first.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Amr Fakhri буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 1,535
