Nikon D500 — это зеркальная камера формата prosumer, выпущенная в январе 2016 года.
Metering Mode button not working
On my D500, the Metering Mode button isn’t working. The other 3 buttons (WB, QUAL, and Mode) are working. It has already been into the shop once (6 weeks and $150) to just be told there was nothing found and it’s working now!
A couple of times, a sharp hit to the top left corner would have the button working again, but not this time.
Since I’m in IT, I suspect it is just a cable that is loose.
Is there a teardown of the D500 that shows where all the screws are that I need to remove?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
I have opened it up myself, and reseated the connector inside the top assembly, as it was out of place. When I put it back together, it didn’t work, but a 2nd reseat worked to get it functional, not sure why.
I am going to work on making a repair guide; not sure when it will be ready.
I have created the guides of the steps that I took to resolve my issue: Ремонт неработающего режима замера экспозиции
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Thinking the first attempt, I may not have seated the tiny cable just right, and had to do it again. I am at 6 months, and it has not had any sort of failure of the button.
из Поделиться
Добавьте свой ответ
Wolphin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За все время: 562
