Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
Screen brightness resets after restart
I have a Galaxy Tab A 8.0 SM-T387 that has a brightness issue. After I start it up, the brightness is all the way down on the dimmest setting. I turn it up and it stays up, thankfully, but when I start it up again, the brightness is all the way back down again. Is there a way for me to force it to keep the brightness where I put it?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
After you have adjusted the brightness setting, re-start the tablet in safe mode and check if the setting is still correct.
If it is then a downloaded app may be the cause of the problem.
The trick is to find out which one is the culprit.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
godingservices буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 1,550
