Repair guides and troubleshooting for the HP Compaq DC7500, a business class desktop computer introduced in 2007.
28вопросов Показать все
My pc is not starting just making beeps 9 times with red light blinks
my pc is not starting just constantly beeping for nine times with red light flash again & again. I can’t recognize what problem it has, I watched some videos to fix it on youtube but I find out that my pc is beeping for 9 times all of the videos that I watched on youtube have the solution for 5 beeps none have 9 beep problem solution.
Это хороший вопрос?
Оценка 5
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Here’s an image taken from page C-11 of the service reference guide for your desktop, which shows what a 9 beep error code can mean.
It could be a faulty PSU so check the various voltages being supplied by the PSU to the motherboard to make sure that they are all OK.
If they are OK then it may be a CPU fault or a motherboard fault.
(click on image to enlarge for better viewing).
Hopefully this is of some help
Был ли этот ответ полезен?
Оценка 6
1 Комментарий:
You need to replace supply other wise motherboard need to replace
из
Добавьте свой ответ
Moazzam Ali будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 22
За последние 30 дней: 141
За всё время: 11,474
