Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Boot Loop after lightning port replacement
Hello,
I just finished a replacement of the lightning port on an iPhone 7. It now attempts to boot but flashes off an immediately back on (like its cycling re-boot sequences. I’ve rechecked that all connections are seated properly.
Here are a couple of small places I feel like it *may* have gone wrong? First, I had trouble plugging the speaker and microphone connections back in place. They are seated now but…that was a challenge. Second, I mistakenly plugged the battery back in before I had re-connected the screen. Could this have shorted a battery connection?
Its not a software issue as iTunes won’t recognize it, nor will my MacBook.
Could it possibly be a logic board malfunction? I’ve read this is common in the iPhone 7 but I don’t have the setup to check or repair a logic board. Is it worth attempting to replace the logic board or….should I just find a used iPhone 7 replacement?
Any suggestions kindly appreciated .
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Try booting with the charging port unplugged. If it works unplugged it is a problem with the charging port.
I think there is a quality problem with the replacement charger ports so I always go for OEM or OEM pulls rather than aftermarket because I have had some where they don't align properly to plug into the connector matter what.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks for the reply. Same affect whether the charge cord is plugged in or not. I had an iPhone 6 do this with bad connections but I'm quite sure everything is seated well this time.
из
try disconnect the battery n the charger port connector. plug them n try again if it not work this video can help you solve the boot loop https://youtu.be/0XGMFmHLFCw
Оценка 1
Добавьте свой ответ
Ajeet будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 1,568
