The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
33вопросов Показать все
Вопрос закрыт
Is it possible to repair a broken power button?
Motorola Droids have a well-known power button issue, where the power button stops pressing after some time. Does anyone have experience repairing this? I saw one report that just filing away a bit of the back case around the power button will fix the issue; has this worked for anyone else?
Это хороший вопрос?
Оценка 0
Добавить комментарий
5 Ответов
Depends on what's causing the malfunction. If the button is just not registering because it's not being fully pressed anymore filing away a bit of the case or cleaning any debris from underneath the button may fix it. If it's an electrical issue it might be much harder to track down.
Был ли этот ответ полезен?
Оценка 0
The round copper contact under the button that flexes and connects two wires on a ribbon has fallen off the ribbon. they are $13 for the tiny item online(google). you will need a t5 tork to open the back cover. you will also have to peel the speaker, camara, and antenna covers off to get to the screws. they are $5 each to replace and the sticky will not save. search youtube for a video show exact steps to open. Best left for someone with experience working on phones.
Оценка 0
Этот ответ изначально был на другой вопрос.
Anyone know the name of the part, to fix the power button issue? Does Ifixit.com have it in stock?
Thanks!
Оценка 0
I replaced one of these monday and it was not that bad. I ordered a new flex and used a heat gun to soften the glue on the flex so it could easily be removed and reinstalled. Be careful with the vibrator part of the flex it can be damaged easily. Take your time and install just like it came off and you will have no problem. This is a pretty easy phone to work on. I did not need to purchase any extra parts to complete the repair. I used double sided tape to replace any tape that did not restick. If you use heat to remove the covers the tape should come off with no problem.
Оценка 0
Where do you get the new flex?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 4,080
