The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
28вопросов Показать все
My marker lights quit working on the front and back of my truck. I’ve
My marker lights quit working on the front and back of my truck.  I’ve checked fuses and they are good but there is no power we’re the fuses are. Replace light switch and no change. Any suggestions?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @bigkev8
Not sure if it is the same for your year model, but in the 2010 Silverado the power to the parking light fuses is fed by the park lamp relay that is operated by the BCM when the light switch is operated.
The relay is located in the under hood fuse block.
Here’s an image taken from the 2010 Silverado owner manual showing the location of the relay in the fuse block and also an image from the 2010 Silverado electrical wiring circuits showing how the BCM (blue box) operates the relay (red box) to supply the fuse(s) (green box).
(click on image to enlarge for better viewing)
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Kevin vandersteen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 20
За последние 30 дней: 53
За всё время: 5,121
