Why is my Speedometer lights not working
I replaced my bulbs and my fuses for speedometer every other light works but that one and it’s still not working I really don’t know
Это хороший вопрос?
Это хороший вопрос?
Hi @ricky_walks2000 ,
Did you check that voltage was reaching the bulb when you replaced it?
Even though you replaced the bulb doesn't mean that there isn't a break in the circuit to the bulb from the light switch.
Assuming that all the other lights in the instrument cluster are working the problem must be in the instrument cluster.
You need to trace the circuit from the speedometer light bulb to the light power rail in the instrument cluster (power that is supplied by the light switch) and to the earth connection in the instrument cluster to check if there is an open circuit preventing the light from operating.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 84
