The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151вопросов Показать все
Areas of screen unresponsive to touch after screen replacement
I am just about done with the iPad 6 Wi-Fi Front Panel Assembly Replacement procedure. The LCD is screwed back in with the new touchscreen connected. I turned on the iPad to test the touchscreen (before final step of removing adhesive strips and securing touchscreen down).
Home button works fine - iPad lights up and when I go to enter my code, the 4, 5, 6, 7, 8, 9, and 0 all seem to work but the 1, 2, and 3 buttons do not respond to touch. “Delete” and “Cancel” text buttons both work.
I am able to power down (by sliding across the top of the screen) fine. Tried a hard reboot but same issue persists.
Is this a problem with the iFixit replacement screen or could there be another issue?
Thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Oh yeah I get this a lot with my iPad 6 screens just disconnect the screen cables and reseat them. For every one I do I plug them in two times to make sure.
I'm not sure why but with first click in it sometimes has dead spots on touch but when I reseat it is all working fine. Make sure to push down a bit harder than usual on each ends to make sure they are fully clicked into connector.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks! I will try this and report back!
из
Belated update: this fixed it - thanks!
из
Добавьте свой ответ
Matthew Wilson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 17
За последние 30 дней: 79
За всё время: 1,651
