Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798вопросов Показать все
What should I do when I get the "very low battery" message?
I have replaced the hard drive in my 30GB iPod Classic. The backlight will not light, and all I can see is either the Apple logo or the message: "Please wait. Very low battery."
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I would of course start with he battery and replace it. Check the dock connector (where the cable plus in) make sure that you do not have any bend pins, that there is no corrosion on the connector and that there is no debris inside the connector. When you replace the battery, check the connector itself. It is a little flimsy design and has the tendency of easily breaking of the logic board. If you have a firewire adapter for your iPod you could try to charge your iPod with that since it does supply a little higher amperage. Good Luck
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
David Zack будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 748
