Car dies while driving
I have a 1999 honda accord lx and recently the car has just been cutting off while driving. I can get it to start again but only once it cools down. Is this a possible starter relay issue.? Thank you for any advice you can give.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Probably not the starter relay since that wouldn’t kill the engine. First step would be to see if there’s anything specific that’s happening when the engine dies. For example, is it only after reaching a certain temperature? Or only when turning/going straight/hitting a bump? If it only starts again after cooling down, that indicates it’s a cooling system issue. There might be an overheating problem or there might be an ECU issue that’s misinterpreting temp sensor or other engine parameters. Unless the engine dies at a very specific time, every time, it could be difficult to diagnose without ECU/BCU/engine code reading tools.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Devon Blom буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 469
