Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
iPhone 4s suddenly will not charge and home button unresponsive
I have an old spare iPhone 4s, which has been connected to an iHome speaker since the time I upgraded to a new phone years ago. Being that it was always docked with the iHome, its battery charge should have been at 100% at all times. Yet, a couple weeks ago, I saw where the percentage had dropped from one day to the next. In inspecting this, I also found that the home button has stopped working. I can turn the device back on by swapping in another iPhone 4s’s charged battery. While powered on, I can observe that the home button remains unresponsive and that the iPhone will not react to being connected to a power source. I have swapped out cables in the mix of this, with no improvement (same cables power the other 4s I have just fine). Any easy fixes to explore, or is this unit ready for the recycle pit?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Sounds like the charger port needs to be replaced.
Though the home button not working as well is not a easy fix as that requires disassembling the whole phone to where the logic board and screen is removed.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
dpw95 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 34
