The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Color screen not working well
My LED screen is not working well my screen had broken so I replaced that but now my LED is distorted I teoes connecting the cables on the back but no luck
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Estela Villafuerte  double check your work. Make sure that the ribbon abel for the screen is properly inserted. Remove it once and try to reseat it. If all of it looks okay (check the connectors for broken bend pins etc. as well) then it is possible you have a bad screen. You may have to return it and request a replacement.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Estela Villafuerte буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 107
