Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782вопросов Показать все
battery issue - no charging
Hi Everyone.
I have a Macbook Pro 2011 as above and recently I took it to remove OSX and re-install when found out it wasn’t working as before. In fact wasn’t working at all. Hard to start the OS and when started slow like a Windows PC. Checking upon battery charge I noticed it was empty and no charging was being given. I left the Mac idle for a long period and probably the battery was decayed it charge to zero or near that.
FYR it had 250 cicles (abt) used and was working normally and in a good way before I stop the Mac.
The point now is:
I’ve made several attempts with the reset of battery via keyboard, detaching her plug from main board, etc, but none seemed to work.
So I hope can reach any of you to have good news on that.
Thanks in advance for all cooperation given to my request.
Best regards,
Marco
Brazil
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Let’s take a look at that battery will a better tool. Please run this program and post your results.
https://coconut-flavour.com/coconutbatte...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Marco Bella Rosa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 39
