Replacing Front Glass ONLY,
How Hot does the front glass have to be to starts to separate from LCD?
Это хороший вопрос?
Это хороший вопрос?
The point I was trying to get at is glass only on OLED is nearly impossible because of how fragile it is.
Был ли этот ответ полезен?
The pixel 2 uses an OLED panel, which are SUPER thin. Anything with an OLED panel is unfortunately very difficult to do a glass only repair on with a very high failure rate.
So how many degrees C° should I set my LCD separating machine at if it's OLED ?
But it can be done right? Try using cold instead of heat,or would that matter when dealing with fragile OLED screens?
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 599
