Clone HDD 750Gb Toshiba MK755.. will not boot
I am upgrading my HDD on my 2011 Macbook pro, with a 750Gb Toshiba MK7559GSXP I used CCC and SD to clone the drive , the cloning process finish with out any flaws, afterwards I tested the Clone HDD by restarting the computer and pressing the option and booting from the Clone HDD, it work fine, I proceed it to install the HDD on my 13" Macbook pro, I restarted the computer and after 60 seconds all I get is the Flashing folder with the question mark, I remove the HDD and install the old HDD and boots fine.
Это хороший вопрос?
1 Комментарий
I'm having the same problem and have tried every variance of drive size, cache speed, rotation speed, and jumpered the pins of each SATA drive to limit the transfer rate to 1.5 instead of 3gps. Thru forum surfing I also learned about Apple's SMS motion sensor detection that may conflict with internal drives but NOTHING has worked. I can always boot my cloned drive externally via USB but all I get is the folder with a ? when it's installed.
I'm finally reaching my breaking point....
I'm working with my 2007 MBP 15" 2.2 w/2.33gHz with 4Gig RAM
из michael zoz
