Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
82вопросов Показать все
Display turning into pixels then turning off.
My MacBook never fell or anything, but since about a month my MacBook has just went black, made these pixel thingys. I turned it off and after it was fine. Now my MacBook doesn’t turn on again. Have a video of it.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Sadly, I’l thinking the logic board graphics circuit had a failure. This series logic boards are very difficult to fix. Which only leaves replacement.
Hopefully you’ve been good on backing up!
Time to visit the Apple Store!
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Is it possible to still access the hard drive?
из
If you can't get it to even respond I don't know of any way. If you can boot up under Target Disk Mode then you might be able to hook up a second Mac via USB-C between them to gain access to your files.
Use target disk mode to move files to another computer & Understanding the Applications for Target Disk Mode
из
Добавьте свой ответ
Donna Krasemann будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 264
