What can I do if c6442 on logic board is burned?
Some time ago my MacBook Pro won’t turn on. After few tries it finally turned on, there was a turning on sound, but after that it turned off and from left side whole came smoke. When I tried to turn it on again, it started and worked normally, but I saw, that there is a burned hole under left shift key.
I took it to the support and they told me that repair is not worth. I opened it by myself at home and I saw, that on logic board are missing two c6442 parts and there is a hole in the keyboard back panel.
Is it worth to repair it or can it be a dangerous in normal use? From what reason could it happened?
Sorry if my English is not good.
Это хороший вопрос?
1 Комментарий
if you want to price a replacement logic board check for the numbers used by Apple 820-4924-A, 661-02355.
из oldturkey03
