Red light on but not turning on
I have a sanyo flat screen tv. FW24E05T. It's in good condition atleast 3 years old never had any problems, but has been sitting for awhile without being used. The red standby light is on when its plugged in but the tv won't turn on. The reset seems to do nothing, unplugging and replugging does nothing, and the light just stays solid red (no blinking, green or blue light). Is there anything I can do or is it toast? Thanks for any help.
Это хороший вопрос?
3 Комментариев
I have same problem. Use remote to try turn on….see green disappears and flashes in sequences of 6. My tv is a Sanyo smart tv. No buttons on back. All remove. Tv less than 3 years old. Can't afford a new one. Never will I buy a Sanyo anything again! Stick to LG electronics from now on ?
из Donna Kayseas-Brown
TV not coming on even after cable reboot
из susanbaker55
@susanbaker55
What is the model number of the TV?
Is the TV's red standby light on or off?
If not on have you checked that the wall outlet is working OK?
If on, have you tried using the TV control buttons instead of the remote?
What have you tried?
из jayeff
