Repair/replace card door Olympus E-510 DSLR
The card door on my Olympus E-510 DSLR has lost the two tabs that engage the catch that keep the door closed. Looking for information on how to replace the door. Thanks!
Это хороший вопрос?
Это хороший вопрос?
I found a replacement door on Ebay for $15, and some general disassembly instructions. The specific repair was done to replace an LCD, so I'm not sure how much of it will apply to you. Feel free to take lots of pictures when you fix yours and create your own guide!
Kudos for rocking the Olympus DSLR, by the way. I have an E-420 myself, and I love it.
Был ли этот ответ полезен?
David- thanks much for the link! Door on my e510 gave out just as I upgraded to an A6000. But I'm still keeping the e510 because I have so much good glass for it and it still takes great photos, if a bit heavy. Thanks again.
The design is the problem. My magnet fix is the real solution! Just follow instructions and click on picture of camera to see how I did it! Replacement door failed too!
I brought some tiny round magnets, which when glued into the place of the faulty clips should do the trick (from Hong Kong) when it happened for the second time with new door! I am working on it now to see how I can glue them into place to keep it shut. Very bad design. Suspect it was designed to fail. Great little camera otherwise. One source of magnets. https://magnet.com.au/collections/disc-m...
E510 Card door....Fixed it. with a eight tiny round magnets .95 X .395 mm ordered from here http://tinyurl.com/mqu2af5, ordered 100 for less than $10. Broke the useless catches, scraped out the small raised rib area to make it flat, super glued tiny magnet into place, did the same with the door side, and added two or three magnets to take up the space. They hold themselves into place but could be glued. Works well. No help from Olympus. Next camera? A Nikon. Bad customer service from Olympus...
Hello, can you come again with the magnet measurements in mm? cannot find that size and have to order them online (link is broken) thanks
Can you share more on the placement of the magnets or pictures of the repair. I too am having this open door error on e510. Thanks
Just put them where they fit on the door. Two or three stacked on top of each other works for me. The yare epoxied or use good plastic metal glue. Don't remember which.
I have done it, replaced the card door I mean.
I followed the "general disassembly instructions" in the answer from Tom Hodson. Many thanks for that link.
After removing all the screws as instructed, I lifted the back cover just a fraction at the card door end of the camera. I then was able to remove the old card door and put in a new with ease.
Thanks David for the link!
Torvald: Good tip! No need to completely remove the back.
Richard: Thanks for the heads up on screw length.
Ian: I don't know about the 420 but on the 510 the 3rd screw was difficult to find. It's on top, sort of under the strap link.
I'm VERY unhappy with the design of this door. I don't abuse my camera and yet the little plastic tab broke off. And it's not easy to find a new door. Terrible design by Olympus!
I also used the same procedure to replace my CF card door for my Olympus E-420 and it worked nicely. Two notes: 1) make sure to keep track where the screws go because they are of different lengths. 2) it's disconcerting that the CF door is held in place by two small pieces of plastic that don't seem too sturdy.
The tabs will break again or stop working. Replacing the tabs with magnets works well...and you do not need to remove door at all!
Just replaced the door on my E420 - good advice above - likewise only necessary to ease the cover open a little to fit the new door - not a big job. General Disassembly instructions above state "Remove the three screws from the card compartment"; there's only two on the E420.
Just for anyone that hasn't realised, I had to change the door because I kept getting a warning that the card cover was open. This was caused by wear on the card door latch.
Thank you all so much! I only had to remove three screws on my E-420, the two inside the card compartment, and the one next to the "Made in China" label on the camera bottom next to the battery door. I was then able to pry the joint "behind" the card door open enough to see the metal rod that the door hinges on and slip it out with a small flathead screwdriver. The new one went in as easily. I had expected this to be painful and time-consuming, but it only took about 15 minutes.
Does replacing the door fix the Close Door error even though the door is closed
so the camera does not operate? I am getting this error from my E-420.
I have Olympus e510 after taking one photo the red light comes on would the door also be causing that problem
I have the same problem but I did not receive any directions with my card so can somebody help
I can't find any one to help my camera is an Olympus e-420 ?
Does anyone have a copy of, or a link to the general disassembly instructions please as the link above no longer works ?
I need to complete this on my E510
За последние 24часов: 12
За последние 7 дней: 25
За последние 30 дней: 100
За всё время: 14,009
2 Комментариев
Thanks, David
I had found the replacement cover on eBay (it's shipping today) and the instructions help, too. Thanks.
I've always like Olympus, and still have OM-1, OM-2, and a new EPL2. They fit my hand just right, and I like the way they think.
Tim
из tjod
Door will cause problems again. See small glued magnet fix by me below. that's how Olympus should have made these with a magnetic door catch!
из JohnOh
