Серия ноутбуков HP Pavilion dv9000 была представлена в 2006 году.
Best way to reflow?
I am looking into the heatgun, blocking the vents(wow, that will do MORE damage then good), reballing, replacing the board if I get the right donor
I have asked about the best way to implement data removal separately and actually made it understandable
How I deal with these laptops is very simple, clean the heatsink, get Artic Silver 5, replace the thermal pads on these ticking death clocks to keep them around longer(I get it, I CHOOSE to take these)
I will do this on ANY NVIDIA plagued laptop I need to fix to keep them from dying again as quick(I have worked on a friend's with a reflow, it lasted 2 years before it died, better then a year and then it died before)
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Выбранное решение
dv6/9 series are doomed
dont try to fix it at home
you need 220-230C to smelt the tin
but you kill the chip with 250C (celcius)
and it will brake again if not done properly
reballing with new tin would work for half a year
but the chip goes too hot by default so why bother?
Был ли этот ответ полезен?
Счет 3
13 Комментариев:
I was just a little critical about it
из
I came to my senses earlier and realized i was being a bit too critical
из
Aoyue 2702 + is a great rework station with digital thermal control. I would recommend using this or something similar if your interested in rework projects. its only $299.00 at Amazon and I've owned mine for 2 years without a problem.
из
Sorry forgot to add you can buy a can of super cool ( a refrigerant), its safe to use but don't directly in-hail it. it runs about $9.99 as well. You spray the chips periodically to help keep the chip below the 250C mark.
из
Using the refrigerant as you suggest is a VERY bad idea for a number of reasons including but not limited to causing bad solder joints, lifting chips off the board, warping the board and causing the board layers to separate.
из
Показать ещё 8 комментариев
Give it to a computer shop and tell them to remove the gup chip set and use leaded solider. This issue occurs because HP used non leaded so it has a low melting point than leaded. I did the same thing and mines working fine its almost a year now. I also cut a hole in the bottom cover and added a extra PS3 fan to all the device to breath more heavily.. No problem with it now works like a charm no over heating issues .
Reball wit leaded solder!
Счет 0
Is it possible to remove the discret GPU and use the onboard chip ???? remove physically and from BIOS or something? ( Of course...only after reflowing and being able to power on once again..)
Счет 0
Добавьте свой ответ
Nick буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 25
За всё время: 11,147
