The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
523вопросов Показать все
Screen flashes on for a second then off after repair
I recently got 2 galaxy s4’s both working fine but one had a damaged screen the other one didn’t as the one with the good screen any way I decided to swap the motherboard from one phone to the other and with a bit of experience with repairing phones I’m pretty sure I did not break anything but when I tried turning the both on after the swap they both just flash on and then straight off again I swapped them back and they worked fine also they are both different model numbers any idea if I swap over every component rather than just the motherboard if that might work
Это хороший вопрос?
Оценка 0
2 Комментариев
Tao Rain "they are both different model numbers" give us those numbers
из
Yeah one gt9506 and other one is gt9507
из
Добавить комментарий
1 ответ
Выбранное решение
Hello,
I had a similar issue with either Samsung S5 or newer. Bought a new screen and it wouldn’t work. Turns out the screens can’t be just swapped between different model numbers. Screen xxxx won’t work on a yyyy motherboard.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Yeah makes sense
из
Добавьте свой ответ
Tao Rain будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 36
