LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Digitizer Ghost touching after replacing digitizer
i recently replaced my ipad 5 LTE digitizer and it was working fine after the repair but the home button was loose so i figured ill put some glue on the piece that holds it in place and it’ll stick. It fixed my issue but now i have a lot of “ghost touch” on the display.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Check that there isn’t any pressure applied to the screen around where it’s ghosting. If you had to remove the display to fix the home button issue, you could’ve damaged the digitizer flex cable.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Kamil Malec буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 167
