Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
Glass only screen repairs removing frame
Hey so I’m looking to do a glass only screen repair and would like somebody to talk me through it, I have one main question though, most videos I’ve seen have shown people removing the frame first, is this a necessary step and if so why? My screen glass is very shattered and I’m confident I can remove it without taking off the screen, is it a necessary step?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
yes you need to remove frame in order to run wire though on hot plate be careful the ribbon wires at the bottom of the displays are very fragile also use 0.04 wire and high heat do not try to do it a different way it doesn’t work believe me i have tried
Был ли этот ответ полезен?
Счет 0
4 Комментариев:
Can you not run the wire through the screen and the glass while the frame is still on? My glass is extremely shattered I feel like I probably don’t need heat it’s shattered to a point where I could probably pick it off with my hands
из
no the frame on the screen prevents you from being able to fully run wire though
you need high heat 105c to 115 c at least this loosens the oca from the display oleds screens are very fragile
you use wire because it allows you to remove the glass some what safely remove the glass you could try and pick off the glass but glass broken glass have very sharp points and any of them could damage the screen
из
When you attempted to do it without removing the frame what happened? Was the frame a big obstruction?
из
ya the frame wraps around the display and prevents you from getting a good starting point to put your wire though
из
Добавьте свой ответ
ismail soleiman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 154
