Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
55вопросов Показать все
VCR not functionally normally.
I have a Samsung DVD-V2000 DVD/VCR Combo. Lately ,when I plug it in, it makes a buzzing sound and the green power light flickers. Also, nothing comes up on the LCD, no mechanical sounds, and it just doesn’t start up the way it normally would. I would really like to know what could be causing these issues and how can they be fixed.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Vaughn Gracey this “it makes a buzzing sound and the green power light flickers “ makes me think you’d be looking at a power supply issue. You will have to start disassembling your device and use a multimeter to check out the power supply. Post some good pictures of your boards etc. so we can see what you see and hopefully can help you out further. Adding images to an existing question
Check something like the no power situation and see if it gets you near the components you want to check out
Here is how to disassemble it Samsung DVD V2000 Disassemble
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Vaughn Gracey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 99
