I can't turn on my Notebook! I would need some help :(
Hello everybody,
I opened my Notebook Asus KV550VX to replace my old keyboard since it wasn’t working properly due to a mistake of mine (I accidentally spilled coffee on my Notebook). So after replacing it, I closed my Notebook and connected every ribbon cable properly but then I got a bad surprise! My Notebook did not turn not. I tried to buy a new ribbon cable for the power button but I wasn’t able to sort out this problem since even with the new cable the PC doesn’t turn on. As a result when I press the power button I get some lights on for an istance but nothing works. I can’t even hear the CPU working.
I took a picture of my motherboard ribbon cable clip and started wondering about the situation. I noticed some pins look like they are damaged and maybe this is the real reason why the Notebook does not turn on. What do you think about it? I don’t know what else could be. I can’t figure out what the real issue could be if not the motherboard pins (maybe burnt by the coffee).
Thanks to all who will reply
Greetings
Это хороший вопрос?
4 Комментариев
What did you do immediately after you spilled the coffee?
из mike
Hi @sicario98 ,
Did you disconnect the battery from the systemboard after opening the laptop but before working on it, you didn't say?
из jayeff
@aactech Unfortunately I didn't immediately turn off my PC but kept using it for like a half hour...Ony at a later time I read about turning it off as soon as possible
из Maira
@jayeff Yes, I did
из Maira
