1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
191вопросов Показать все
What to repair with swollen battery?
Hello all
I found an old Macbook Air of my girlfriend which she doesn’t need anymore. She stopped using it because of the battery that was swollen (see attached pics). I know that when you take it to the Apple Store, they will also replace the top case.
I like projects like these (trying to make it good again). I know it’s an old thing and is not really worth my time, but like I said, I like it. Am I okay with only replacing the battery or do I need to replace more?
Thank you!
Korneel
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You’ll need to start by replacing the battery MacBook Air 11" Mid 2011 Battery Replacement. You’ll want to make sure the MagSafe charger is the correct one and is a REAL Apple unit! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth as they can damage your systems charging logic. Here’s how to check the MagSafe connections Apple Portables: Troubleshooting MagSafe adapters
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
TheRadioApoc будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 156
