Released February 2013, identified by the D7100 badge on the front right side of the body.
Вопросов 13 Показать все
Light spot in photos
I purchased a Nikon D7200 (almost identical to 7100) from a guy on Craigslist and he said it had a sensor scratch, after looking at photos of sensor scratches I don't think that is what it has. When taking photos in daylight at low F stop a light spot appears in the photos. I have tried switching lenses with no change, as the f stop gets higher the spot goes away. What is this and other than replacing the sensor is it fixable?
This photo is UNEDITED
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (3)
Whatever it is, the fact that it goes away (progressivle, I presume?) as you increase the f stop indicates it’s not in the focal plane (where the sensor is).
I’m more familiar with compact digital cameras, but these have a focussing lens which sits just in front of the sensor and is moved forwards or backwards in order to focus. This might be in the right position to cause the spot.
Был ли этот ответ полезен?
Оценка 0
I have a D7100 camera with the same problem. It happened while using a wrong shutter speed (too slow) while framing a scene featuring the sun.
My guess is that the CCD sensor was damaged where the sunlight left a burn-in mark.
EDIT - the shutter curtain was damaged (see my new answer)
Оценка 0
Try the following: take a photo in delayed shutter mode. The first press will flip the mirror up exposing the curtains of the shutter. Do this without a lens so you can see the shutter blades.
In my case I could see a hole burnt in the shutter due to sun damage while using a tele lens.
I ordered replacement curtain blades and will attempt at replacing them on my D7100.
Оценка 0
Добавьте свой ответ
Josh Mcdermott будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 230
