Clothes dryer repair and support guides.
870вопросов Показать все
dryer was working fine then next day I had no power to the dryer
Hello I have Samsung dryer model DV431AEP/XAA dryer was working fine then next day I had no power to the dryer at all check braker / thermal fuse and still no power anyone need help?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi @analisa24,
Did you check if there is power available at the wall outlet, you didn’t say?
If the wall outlet is OK, disconnect the dryer power cord from the wall outlet and then test the cord using an Ohmmeter to prove continuity of all the wires in the power cord from the plug into the dryer.
Here’s a composite image taken from the service manual for the dryer, showing the wall outlet power connection and also the No Power troubleshooting flowchart.
(click on image to enlarge for better viewing)
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Analisa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 219
