Which screws does MSI gs63 use?
I want to replace my MSI laptop screws because they are broken.
Это хороший вопрос?
Это хороший вопрос?
From what I can find it is M2.5 x 6.5mm, Phillips Head #1 screws.
It sounds like the screws are stripped, so this guide may help you get them unscrewed if you have a hard time doing so.
How to Remove a Stripped Screw
Hope this helped! :D
Был ли этот ответ полезен?
Thanks you !! I will try it immediately.
No problem and good luck! :D
hello from france is it okay with Msi GS66 ?
За последние 24часов: 2
За последние 7 дней: 22
За последние 30 дней: 59
За всё время: 5,431
2 Комментариев
What screws are you wondering about? The ones for the bottom cover?
из Erik Eriksson
Yes, the first ones that you need to remove. @eke0909
из Jiahao Cheng
