Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
Replacement fan is not working
Last night I replaced my Switch’s fan with one received from iFixIt. After closing the system and powering it up I thought it sounded a little too quiet. I gave it a few minutes and the fan never seemed to spin up. I took the back cover off, not the plating, so I could see the fan while the Switch was powered on. It wasn’t spinning at all. I took everything apart and put the old, extremely loud fan back in and that fan spun up as it should, albeit quite loudly. I tried re-seating the cable for the replacement fan and that did not help. Did I simply receive a defective fan or is there something else I should check or be concerned about?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
Hi @aaronw630
Since you mentioned you swap the old fan and it works,
Contact Ifixit, most probably the item is DOA
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
how we can fix the switch for the fan
из
Счет 0
Добавьте свой ответ
Aaron буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 1,180
