Screwdriver for Philips M1.2x2 screw?
Hi there,
My LCD screen on the XPS 13 9300 got damaged and I am looking to get a replacement for Dell. The screen replacement process seems easy enough so I thought I could do the re-assembly myself and save on labour cost (plus with the current situation, it’s kinda difficult to obtain service anyway.
There are three screws, however, which seem to be Philips type screws measuring 1.2mm in diameter. It is listed here: https://www.dell.com/support/manuals/sg/... as the “Display-assembly cable holder”.
May I know which Philips screwdriver would be most appropriate for this? I saw that there are #000 and #00 out there but they seem to be for 1.5mm and 2mm heads? Would like to avoid stripping the screw if possible (the user guide already adds a caution to avoid torquing the screw too much—I’m guessing it’s a really fragile screw).
Это хороший вопрос?
1 Комментарий
Hi Reuben,
Where did you order a replacement screen for your Dell XPS 13?
I can’t find any good website.
из Niels Anné
