Screen replacement needs calibration
Several iPhone 8 Plus problems with replacement screen not functioning correctly has been diagnosed as needing impossible-to-get Apple Calibration. This makes replacing a cracked screen problematic. Is this a common problem making the $80 new screen just not worth it?
Это хороший вопрос?
Счет 0
2 Комментариев:
What calibration are you referring to? Calibration to maintain true tone?
из
Okay, I never heard of True Tone, so it is probably that. Several posts for iPhone 8 mentioned that new screens lacked proper functioning when replaced with a stock screen. Reply was essentailly this can only be corrected with a calibration device only Apple possessed and the only way to fix it in the wild was to switch out screens until one matched and did not need calibration.
из
Добавить комментарий
