USB-C port works only one way
Hi,
I discovered that my USB-C port on the bottom right-hand side doesn’t work properly.
It works only from one side, meaning that if it doesn’t work I have to unplug the cable turn it around and plug it back again in order to work.
I’ve already reset NVRAM and SMC and I also replaced both ports on the right hand side, still didn’t solve my issue.
Does this mean that my logic board is faulty? The connector itself looks OK to me.
How can I check if it’s the connector? Do you have any ideas what I could try to repair this?
Best regards
Это хороший вопрос?
