Battery not recognized after replacement
Hi guys. Just installed my new battery, and it is not being recognized at all. I’ve retraced my steps several times, I can’t find anything wrong.
Laptop still boots and functions normally when plugged into power, however the battery doesn’t gain charge, and the computer doesn’t seem to recognize that it exists at all. If I check “show battery status in menu bar” the icon appears for a split second and then disappears and the option unchecks itself. (I booted the computer with the battery connector board not connected or screwed in at all and it behaved the same way)
Connections are all good as far as I can tell, the interposer and the posts seem fine, anything that I’ve seen in the comments on the process hasn’t applied to me. Like i said the computer functions normally when plugged in but dies immediately if power is taken away. So process of elimination points me to the battery and its connection to the computer
Help please!
Это хороший вопрос?
Счет 1
Добавить комментарий
