2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467вопросов Показать все
Replaced battery after liquid damage, still does not recognize battery
I had a liquid spill on my laptop after which it stopped recognizing the battery. We replaced the battery with a replacement from iFixit, but even after doing so it still does not recognize the battery. I’ve reset the SMC and the PRAM but it had no effect. I ran a diagnostic (powered on the MacBook by holding P), and it indicated that there is no battery installed. Is there something else that I can try here, or did some board or chip get fried?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It probably means that the logic board has corroded. You’re lucky it turns on at all, take it in to a repair shop at some point and they can diagnose it.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
EmBer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 38
