The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623вопросов Показать все
Display stuck on Black Screen with 4 Vertical Lines
Early 2015 13” MacBook Air crashed suddenly while on a Zoom Video Conferencing Call and now turning ON but stuck on black screen with 4 vertical lines, no Apple logo or startup chime.
Can anyone help me out in troubleshooting it?
Update
Это хороший вопрос?
Оценка 0
2 Комментариев
Can you post a picture so we can see Adding images to an existing question
из
Hi Dan, I have uploaded the Display Image
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Ouch! Not good ;-{
Your logic board died! This series uses the CPU graphics engine which has failed. You are seeing the scan lines of the video RAM in this case the systems RAM.
You’ll need either a:
And here’s the guide to put it in MacBook Air 13" Early 2015 Logic Board Replacement
MacBook Air 13" (Early 2015) 1.6 GHz Logic Board Изображение
Продукт
$169.99
MacBook Air 13" (Early 2015) 2.2 GHz Logic Board Изображение
Продукт
$349.99
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks Sir, For helping me out but the cost of replacing the logic board is very high, is there any other solution like chip level repair
из
In this case the CPU chip is just not available and you won't have the needed to tools to replace it. Even I don't have the needed gear!
The cheaper solution is replacing the logic board.
из
Добавьте свой ответ
Arun Nayak будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 322
