tried everything . and I do mean everything.
1058pm i am jacks cautious lack of revenge
took video card circuitry only out of oven
by setting it to 450* degrees and leaving it in the oven
as it preheats…
took it out let it cool the R9 270x 2gb MSI
then put the circuitry
and video card back together in my computer which has a 1000watt dell power supply and an I3 4160 gigabyte board
everything is hooked up properly
such as 2 6pins in the video card, etc etc
the card WILL NOT SHOW VIDEO
i have plugged in dvi and hdmi
to the dvi / vga monitor. hdmi with adapters.
NO SIGNAL.
i have tried a 430 watt power supply.
what im trying to achieve oh YEAH a video card that outputs video.
EVERYTHING ELSE WORKS such as if i use a different video card in the
i3 it boots just fine
all signs point to this video card
Update (05/23/2020)
Also bios was reset windows reinstalled
tried installing drivers manually but of course it says no hardware found
still posts on motherboard video while card plugged in
Update (05/23/2020)
3.6ghz Intel i3 4160 cpu
Update (05/23/2020)
gigabyte ga-h81m-ds2v
Это хороший вопрос?
8 Комментариев
Hi
Has the card worked OK in the motherboard before?
If not what is the model number of the motherboard?
из jayeff
I’m sorry im not 100% computer literate
as far as i know the card has never worked
the motherboard is a i3 4160 @3.6ghz
из chukyx007
But the fans spin on the video card that is all
из chukyx007
Is it possible that the i3 is too high of frequency?
3.6ghz that sounds high
из chukyx007
I mean I’ve heard of much higher frequencies
But not on “my” computer
из chukyx007
Показать ещё 3 комментариев
