Bose Wave Radio AWR1-1W, также известный как Bose Wave Radio I, был выпущен в 1993 году. Это настольная AM/FM-радиосистема с высокопроизводительным стереотюнером и двумя независимыми будильниками.
Unit seems frozen, all displays lite, no reaction from buttons
Unit seems frozen, all display is lite, no reaction from pushing buttons
Это хороший вопрос?
Счет 1
1 Комментарий
Is anyone going to reply?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi,
Have you tried a power refresh to see if this resolves the problem, you didn’t say?
Here’s the procedure:
Disconnect the power from the radio and also remove the 9V backup battery from the radio.
Press and hold the radio’s power ON button for 10 seconds and then release.
Reconnect the power to the radio and check what happens when you try to turn it on.
If it works check the voltage of the backup battery before reinserting in case it needs replacing
If still no good then the radio will have to be opened and the motherboard checked for any obvious problems. I cannot find the schematics for the radio online which would help further. You may have better luck by searching for the (insert motherboard ‘board number’) schematics as there is nothing found when using the make and model number. The board number will be printed on the motherboard. Here are the ifixit Bose Wave Radio AWR1RG guides which may help with opening the device.
The answers in this link may also be of some help, but maybe not. Total functional failure and no diplay
Был ли этот ответ полезен?
Счет 1
Mine had the same symptoms. approximately 25 years old. I measured those capacitors 1000µF/35V and 470µF/35V with high ESR. Replaced them and it worked again. costs 40cent for new capacitors. I hope it helps someone else too. Good luck.
Счет 1
Добавьте свой ответ
Joe Warwick буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 20
За все время: 764
